Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Honda Civic Cooling System Problem
Old Jul 9, 2015 | 07:19 AM
jamie_0192's Avatar
Icon2 2001 Honda Civic Cooling System Problem
so the other day i had my cars tires spinning and i had some bad wheel hop and the car completely shut down smoothly (not an aggresive stall). i turned it back over and it fired up and got it home. started the next morning and i noticed after my normal drive the temperature gauge did not raise at all when it is normally at full temp by this time. i replaced the thermostat, temp sensor and rad fan sensor. car constanlty idles like it's cold (1200 RPM), fan wont kick in and temperature will not raise. I drained the coolent, filled, burped it and replaced the water pump as well. i drove the car about 15 minutes and i couldnt smell anuthing burning but im worried to drive it and have it overheat and wharp. Any suggestions as to what may fix this
Old Jul 10, 2015 | 08:52 AM
Curiouz_G's Avatar
Default Re: 2001 Honda Civic Cooling System Problem
Have you considered maybe the cluster gauge is broken?
wanna b R
Sep 16, 2018 09:08 AM
Asmooh
18
Apr 15, 2014 07:05 AM
ericrcan
Nov 19, 2012 12:00 PM
gqstatus05
Mar 2, 2012 08:10 AM
JoeCereghino
17
Nov 30, 2008 08:41 PM
