01 4cyl Accord bad rattle (Water Pump?)
Old Jul 7, 2015 | 03:19 PM
seandabean's Avatar
Default 01 4cyl Accord bad rattle (Water Pump?)
I drive an 01 Honda Accord and 2 nights ago it started doing this. Here is a recording of what it has been doing, recorded with the car idling after 10+ minutes of driving. https://*******/iS1y
I have been reading online and it seems like it might be water pump bearings? Possibly Exhaust manifold rattle.
Here is another video. https://*******/qMP3
Thanks for any help or direction.
Old Jul 8, 2015 | 08:33 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 01 4cyl Accord bad rattle (Water Pump?)
Doesn't sound like water pump to me.
It could be the exhaust manifold has cracked, or the gasket between the manifold and down pipe has failed. Use a quality penetrating oil like AeroKroil on the exhaust manifold heat shield bolts, remove the heat shield, and inspect the manifold for damage.
Old Jul 9, 2015 | 12:32 AM
seandabean's Avatar
I just noticed, my coolant resovoir was 100% empty and the coolant looked dirty inside.
Old Jul 9, 2015 | 09:29 AM
MAD_MIKE's Avatar
MM Gruppe B
Clean out the reservoir, refill.
Verify the radiator has coolant in it.
Verify temp gauge is functional.
Verify oil is full.
freedomlives
Dec 20, 2012 10:56 AM
AmericanPie
Jan 1, 2011 01:56 PM
Elvis1977
Mar 5, 2004 12:23 PM
91DA9
Apr 22, 2002 09:34 AM
