My Civic EJ9 doesn't start - immobiliser problem?
Hello everyone. I own an EDM Civic EJ9, and suddenly it refused to start. When I turn the key, then the green key light is flashing on a dashboard, and car won't start. You can better see the problem on this video:
Any suggestions?
I have the red key. Can I reprogram it myself? Can you explain me what really happened? Is it problem from the key side, or the immobilizer side?
So go ahead and reprogram it. I'm not sure of the procedure but its A DAMN GOOD THING that you have that red key or else the dealer will rape you. It could be an issue with the key-ring. If reprogramming it doesn't work than diagnosing should be next on the list.
http://imgur.com/C8ikL.jpg
It looks like the dealer will have to handle this. So I suggest you take it in for diagnose.
edit: adding more info on red key programming so you can understand why only the honda dealership can do this.
https://uk.answers.yahoo.com/questio...9115952AAnhvbW
But the general rule of the red key is that it can't be used, otherwise it will clear immo's memory and it generates a much bigger costs to fix this. So I'm a little bit afraid to put that red key in my ignition.
happened me before in a eco 1.5 sohc i can't remember what i did but i think i took the chip out of the key and tapped it up to the ignition, if honda is to dear you could always the get immobiliser taken out of your ecu
RinzEG6
Feb 13, 2014 03:20 AM
nhpreludekid
Oct 24, 2013 01:43 PM
