Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2008 Odyssey EX-L - hitch bolts
Old Jul 4, 2015 | 10:50 AM
CylonRed's Avatar
Default 2008 Odyssey EX-L - hitch bolts
Hi,
I need to find out the bolt hole sizes as I need to retap them. Since Honda did not see fit to add in plastic/rubber plug on the holes - after 7 years they are corroded and I can't start the bolts. The hitch came with 12 mm x 1.25 bolts and I need to make absolutely sure so I can get the correct tap.
Thanks,
Brian
Old Jul 17, 2015 | 12:54 PM
TIDYWAZZA's Avatar
Default Re: 2008 Odyssey EX-L - hitch bolts
A Honda dealer could look up the correct bolts for you on the electronic catalogue and by doing this that should also give you the bolt description / specs. This would id them as 12mm x 1.5 or the correct diameter and thread pitch.
crxblues
Aug 6, 2009 11:25 AM
invisible
Welding / Fabrication
Apr 12, 2009 08:26 AM
paulzy
11
Dec 3, 2007 12:43 PM
oMek
May 6, 2004 01:06 PM
