99 Civic EX passenger side power window only rolls up when wet/moisture is present
Hello all,
Sorry for the really long thread title. Anyway, I have a 1999 civic ex coupe with a passenger side power window that only rolls up when there is moisture present (IE, after it just rained, after a car wash, etc). After some time of drying up, the window stops responding. What can be the cause of this?
Thanks for all the help.
Try spraying some silicone lubricant into the rubber gasket where the left and right side edges of window glass slides.
Also consider adjusting the window glass as per service manual instructions.
If these^ don't give you joy, then the window regulator may be bad.
Thank you sir, I will give the silicone lube a shot this weekend. Where can I find a writeup for adjusting the window glass?
Philip
Aug 28, 2003 08:45 AM
