93 honda prelude HELP!!
Old Jun 30, 2015 | 09:28 PM
Crx_Nando's Avatar
Default 93 honda prelude HELP!!
I Just bought this car and the speedometer don't work or the gas and the heat digital display are also not on? a wiring diagram would help but don't know where to look?
Old Jul 1, 2015 | 10:39 AM
Preteclude's Avatar
Default Re: 93 honda prelude HELP!!
Do all the other gauges and lights work?
Old Jul 1, 2015 | 12:22 PM
Crx_Nando's Avatar
Yea all others do the tach works just not the speedometer
Old Jul 1, 2015 | 01:10 PM
backinblue92's Avatar
I would pull out the gauge clusters. I have a '96 and have done that before, it takes all of 30min. Check the plugs. The clusters are all connected via a single dash harness; however the harness has multiple plugs for everything.
Since you just bought the car, you cannot confirm what has been done. Honestly, I hope you carfaxed it. Cause that reeks of someone removing and swapping the clusters as a low-tech odometer rollback, then forgetting or not bothering to plug it all back in.
Old Jul 1, 2015 | 02:32 PM
Preteclude's Avatar
Slap the dash above the gauge cluster. If it jumps when you slap it its most likely a bad connection to the cluster. I would pull the plug and use a dab of dielectric grease and see if that doesn't help. I know it's hard beating on the car like that but it works
Old Jul 1, 2015 | 05:41 PM
thirsk66's Avatar
You first say the speedometer, gas, and temp gauge don't work now you say they work except for the speedometer. If that is the only gauge not working I'd check your VSS and the gauge itself.
Old Jul 1, 2015 | 05:52 PM
Crx_Nando's Avatar
My bad man but yea the gas and the heat display don't light up and the speedometer just stays down no matter the throttle position
Old Jul 1, 2015 | 06:57 PM
Crx_Nando's Avatar
Found the problem
watisjdm
Aug 30, 2009 06:45 PM
97em1
May 11, 2009 07:19 PM
jdmh22luda
Jul 30, 2007 09:58 AM
Jos3ph
Dec 24, 2005 08:26 PM
ThE PiMpiN Co
Nov 22, 2005 08:42 AM
