Crank but no start?
Hey guys, I have a Honda 1999 Civic Dx D16 auto with 120,000 miles on it,while driving it the other day it stalled out on me and would not start back up, after pushing it home and reading online about crank but no starts I tried a couple things, I replaced my spark plug wires, my distributor cap, my Main relay, fuses are fine but no luck, i have checked my fuel pump it seems fine, battery has enough charge, recently got an oil change but still nothing. Is there anything I may have overlooked? Or anything i should double check? I am very limited in the tools i have as far electrical testing goes so any suggestions would be very much appreciated, thanks in advance!
Buy/borrow/rent an HEI/DEI spark tester. You can get one at any parts store for ~$15. Buy a voltmeter. You can get a good one at Sears for $30-$40, or if money's tight, a cheap one from Walmart for $10-$15. Once you have those two things, start off by following the instructions on the HEI/DEI spark tester, and tell us what color your spark is at all four plugs.
Also, thank you for creating a clear and concise thread that gives us the required information
Good OP's like this are disappointingly rare.
christopher.rie
11
Mar 23, 2015 04:09 AM
Canadian_EF
16
Nov 15, 2011 11:10 PM
SilverGT
Dec 2, 2006 03:12 PM
