1996 accord lx with dx motor misfiring
So I have a 96 accord with lx body and a dx engine I keep getting check engine light for cylinder 2 misfire cylinder 4 misfire and random misfire I have replaced the following with no avail egr valve, spark plugs, plug wires, ecu, main relay, valve cover gasket, distributor with cap and rotor, map sensor, idle air control valve, ignition switch, coil, air filter for cold air intake, fuel pressure regulator, oil pressure switch and I have also cleaned egr passages had a compression test done was told all four cylinders where around 150 psi I need help figuring this out driving me crazy so can people please give me there thoughts
LX and DX both used the F22B2.
What is your fuel pressure? If the fuel filter is clogged or the pump is failing you may be experiencing a lean misfire.
Not sure about fuel pressure I jus replaced fuel rail fuel pressure regulator and injectors now it's back firing out exhaust only on a little white smoke I took the screens out off new injectors could that cause this
CChong
Jan 4, 2017 07:38 AM
96civicdx2o3
11
Jan 30, 2013 08:12 AM
achtung
Feb 15, 2005 07:04 AM
