Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
205/50/15 azenis pressures?
Old Nov 4, 2002 | 06:42 PM
Mike D's Avatar
Default 205/50/15 azenis pressures?
Going to lime rock this monday and i want to know what the azenis like for a hot pressure. I was thinking of running 35/36 front and about 33/34 rear cold. what do you guys think?
also, keep in mind the weather temp will most likely be around 40-45 degrees(fun fun with the azenis)
Mike D
Old Nov 4, 2002 | 06:45 PM
HondaRcB's Avatar
Default Re: 205/50/15 azenis pressures? (Mike D)
I'm sure it will be different depending on the car and the track, but when I autocross, I usually run38-40F and 42-45R, this is on a 98 ITR.
Old Nov 4, 2002 | 06:59 PM
BlueR's Avatar
Default Re: 205/50/15 azenis pressures? (HondaRcB)
i will be there for lime rock with azenis also
i'd say start with the pressures you indicated and adjust accordingly after each session to YOUR likings and comfort level with the way the car is handling
Old Nov 4, 2002 | 07:08 PM
Mike D's Avatar
Default Re: 205/50/15 azenis pressures? (BlueR)
Cool, maybe ill see you there. Ill be driving a dark grey/black civic hatch with K1's.
I just hope the tires warm up quick. These tires are shady in this cold weather.
Mike D
Old Nov 4, 2002 | 07:16 PM
bikeboy80's Avatar
this past weekend i was running 38f/35r warm autoxing, if you could call it that on a cold day and they work out quite nicely, i think you're on the right track
Old Nov 5, 2002 | 03:37 AM
CivicSiRacer's Avatar
Default Re: 205/50/15 azenis pressures? (bikeboy80)
I ran 38-39f/36-37r hot at VIR in February.
Old Nov 5, 2002 | 06:05 AM
TypeR47's Avatar
I ran 32/34r to 32/36r cold in 65 degree weather at Puntam Park in October (ITR with 447/673 springs and a stock rear bar). I can't remember the hot pressures... sorry. The car rotated nicely though. 40 to 45 degrees with the Azenis should be fun... at least you're not running a hard R-compound tire
.:Made in OC:.
27
Jul 26, 2008 11:53 PM
thehatchninja
Sep 20, 2006 10:01 PM
Black R
12
May 1, 2004 11:22 AM
vince yeah
Nov 16, 2003 05:34 AM
EGTeK
Mar 17, 2003 10:08 PM
