B20B4 Swap EK
Old Jun 27, 2015 | 12:11 PM
TRWicked's Avatar
Default B20B4 Swap EK
Hi New Here!
So I have a EK coupe EX Manual and I picked up a B20B4 and I've been researching on what I need to make this swap happen I have yonaka B series mounts for my car already and and I'm just wondering what year GSR or LS tranny do I need and if it matters what year?and can I modify my wiring harness to work or should I just swap it out for a Integra harness? And Is the P75 OBDIIA the only ECU that will work correctly?
And are there any other parts I need ?
I tried researching this and found info on the B20Z and didn't know if it was the same?
thanks in advance
Old Jun 27, 2015 | 12:27 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: B20B4 Swap EK
https://honda-tech.com/honda-civic-d...tions-1998336/
Now go read. We don't do spoon feeding here.
Old Jun 27, 2015 | 12:48 PM
White_EG1's Avatar
Actually to even make it easier, here.
https://honda-tech.com/hybrid-engine...s-list-504321/
Old Jun 27, 2015 | 01:54 PM
TRWicked's Avatar
Sorry didn't mean to be that typical newb on the forum just wanted mostly to make sure that there weren't any differences between the B20z and B20B swap wise I read the FAQ section but thank you regardless
Old Jun 27, 2015 | 02:05 PM
NotARaCist's Avatar
As long as it isn't the B20A, they're all the same.
Old Jul 19, 2015 | 10:40 AM
JasonG81's Avatar
Got a quick question for you. I just put a b20b4 in my 92 eg hatch and have a PR4 ecu. Ever since the swap the car likes to idle up and down periodically, not all the time. Could it be the ecu? Thanks
Old Jul 19, 2015 | 11:56 AM
NotARaCist's Avatar
So you decide to thread jack, with an irrelevant issue, while using the wrong ECU, and making it blatantly obvious that you haven't even BOTHERED to try to read the FAQ sticky, which is not only stickied at the top of this subforum, but also linked in the very first reply?
What the actual **** is your major malfunction?
Old Jul 19, 2015 | 12:59 PM
JasonG81's Avatar
Damn sorry man. Was just curious what ecu you used and stating my problem. Didn't know if you ran into that problem with your swap, because I saw you asked what ecu to use.
rx7turbo287
Jul 8, 2017 05:28 PM
2jdmcivcs
Apr 26, 2006 03:13 PM
HybridEL
Mar 8, 2005 05:18 AM
