Coolant spraying out of overflow reservoir
Old Jun 27, 2015 | 11:58 AM
krc91987's Avatar
Default Coolant spraying out of overflow reservoir
First off i have searched this to no avail, car is em1 with built bottom and turbo kit, been having a strange issue where coolant will spray out if the overflow only happens when you get into boost but only the very first time on every drive, ie i drove it for an hour the other day and smelled coolant about 5 mins in then when i got home i checked and it was all dry around the bottle and on the ic pipe that it has been getting on any help is appreciated
Old Jun 27, 2015 | 12:02 PM
W95civicEXcoupe's Avatar
GDD's Resident Derp
Default Re: Coolant spraying out of overflow reservoir
How's that Head Gasket looking.
Mine does the same thing.. because a cylinder combustion is likely getting past the HG, and overpressurizing the cooling system. Sprays out water (coolant?) like you said.
I popped at LEAST 3 hoses after it "sealed" and I said I will not pop a 4th.. Steam every time. Water out reservoir.
So, I say again.. How is your Head Gasket.
It may not be a huge leak but with boost, it may not need one...
(oh and it would then stop because there is not as much coolant to be pushed out. Are you losing coolant?)
Old Jun 27, 2015 | 12:10 PM
NotARaCist's Avatar
I never narc'd on nobody!
What kind of breather/PCV setup do you have? Have you done a block test? Compression test? ...Any diagnostic tests at all?
Old Jun 27, 2015 | 02:17 PM
krc91987's Avatar
The engine has maybe 5000 miles on it and it has a cometic head gasket with arp studs is it possible it could fail that quickly if so that sucks, have not really had to much time to mess with it since i noticed the problem i did replace the overflow cap hoping they would help because it was only like 10 bucks i am using the stock pcv box on the back of the block and the valve cover is running an open hose out the bottom of the car a better breather system is on my to do list but money had been tight lately
Old Jun 27, 2015 | 02:20 PM
krc91987's Avatar
Also i just changed the oil no coolant in it, and no oil in coolant either only coolant lost is maybe 1/4 total overflow capacity then that's it
Old Jun 27, 2015 | 02:37 PM
NotARaCist's Avatar
Well, you have a pressure problem somewhere. Yes, a brand new motor can fail, if it isn't prepped and assembled correctly. Buy/borrow/rent a block testing kit, and also test (or have tested) your radiator cap.
Old Jun 27, 2015 | 02:50 PM
krc91987's Avatar
I'm not familiar with a block testing kit
Old Jun 27, 2015 | 03:03 PM
NotARaCist's Avatar
It's a syringe, a graduated cylinder, and a piece of litmus paper, or other chemical tester. It changes colors if there's exhaust gasses in the coolant. Most parts stores can rent it to you, you'll just have to pay for the litmus, which is only $5-$8 usually.
Old Jun 27, 2015 | 03:38 PM
tony_2018's Avatar
Fish Twig
When was the last time you replace the radiator cap, test it before replacing.
Old Jun 28, 2015 | 03:51 AM
GDD's Resident Derp
grndslm
Sep 4, 2013 10:05 PM
lfunk11
Honda Civic (2001 - 2005)
Jan 16, 2012 12:34 AM
JDM_SOHC
21
Mar 18, 2010 10:14 PM
A-dub5513
May 18, 2009 04:08 AM
GSRaCeRbOI
Jan 12, 2003 06:31 AM
