95 Integra GSR Speedo Needle stuck at 20 mph? Please help
Old Jun 25, 2015 | 12:39 PM
ESP.net's Avatar
Default 95 Integra GSR Speedo Needle stuck at 20 mph? Please help
I have a 95 integra gsr. I did a bastard of a gauge swap. I had purchased a 96 spec ITR gauge cluster which is a bolt in for the 94-97 Integras. I had swapped all gauges from a GSR 94-95 cluster and just kept the JDM ITR 96 spec Tachometer. I had also swapped all needs for the jdm ones. I installed it and everything works but the speedometer it is stuck at 20 mph. I took the gauge cluster out. Re set it with my finger. Drove it and came back stuck at 20 mph.
I was thinking it may be a needle thing from when I swapped them. Is there an easy way to re calibrate the needle? I have the front plastic off the gauge cluster. I took the needle off. Was thinking maybe if I installed in the car turn the car on ignition. It would possibly try and reset the needle post back to 0? Then put needle back on? This work or no? Thanks
I also had swapped VSS. VSS was working before cluster swap.
hype_R
Apr 8, 2008 05:35 PM
pimpnpink
Jan 18, 2008 11:37 AM
blah11
Dec 20, 2007 08:30 PM
95 Gizzer
Oct 10, 2003 01:24 PM
nosmas
Jul 17, 2002 11:51 PM
