Passenger Side wheel wobble
Old Jun 25, 2015 | 09:32 AM
ClermontDelSlo's Avatar
Default Passenger Side wheel wobble
My front passenger wheel wobbles at 12/6 and at 10/2. Ive read that it could be the wheel bearing or the tierods (maybe both?) but also when i jiggle the wheel theres alot of play in the axel, so could it be something else? or a combination?
Old Jun 25, 2015 | 10:25 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: Passenger Side wheel wobble
Time to inspect them then. Do you know how? And what do you mean by 12/6 and 10/2?
Old Jun 25, 2015 | 10:38 AM
White_EG1's Avatar
I suppose he meant the wobble test. 12/6 would be the up and down, but not sure what he meant on 10/2 its supposed to be 9/3 which would be side to side.
Look at the tie rod ends to see if the boot is ripped and/or leaking grease. Same with balljoints. Could be possible wheel bearing if theres still play after replacing the shot parts.
Is the axle cv boot ripped?
Old Jun 25, 2015 | 11:00 AM
24TEN's Avatar
PHANTOM MENACE
Yea the 10/2 threw me off (if that's what the OP meant anyway).
Old Jun 25, 2015 | 11:41 AM
NotARaCist's Avatar
I never narc'd on nobody!
12/6 + 9/3 = wheel hub bearing. That should be your starting point.
suspendedHatch
Suspension & Brakes
Nov 6, 2009 08:06 AM
ketchup
17
Jun 27, 2008 09:02 PM
ITR#132
Nov 27, 2005 08:41 PM
jizno
Nov 23, 2005 01:57 PM
Mr. Vapor
Dec 5, 2002 05:29 PM
