1998 DX D16y7 to D15B swap
Old Jun 24, 2015 | 08:23 PM
Pronoun's Avatar
Default 1998 DX D16y7 to D15B swap
Hey everyone! I bought a Japanese D15B long block as a "direct replacement". Took out the D16y7 and put in the 15. I used all the parts from the 16. The 15 runs and timing is set. But when it reaches operating temp, it revs up and down. Also, under load, it's very sluggish. Help! I thought this would be easy. Lol!
Old Jun 24, 2015 | 08:27 PM
Former User's Avatar
Default Re: 1998 DX D16y7 to D15B swap
Clean the FITV and IACV, and post the CEL codes.
Old Jun 24, 2015 | 08:28 PM
Pronoun's Avatar
BTW, I live in Cali and I just read that a swap for an older style engine is illegal. Is this true? Did get screwed? Was this motor not a "Direct Replacement"?
Old Jun 24, 2015 | 08:31 PM
What ECU?
Old Jun 24, 2015 | 08:39 PM
Pronoun's Avatar
The code was p0113. I'll have to clean those and get back here tomorrow after work. It's the original ECU. 1998 D16y7. Also, the intake is not like every one I see online. The air tube mounts on top and not on the side. I dunno if that matters.
Old Jun 25, 2015 | 02:20 AM
HondaPartsHero's Avatar
Technical Hero
Post pics of your engine including intake manifold, block stamp, head year stamp, etc. Also there are multiple variants of the D15B but generally none of them are "direct" replacements especially if it is the VTEC version.
Old Jun 25, 2015 | 06:08 PM
Pronoun's Avatar
Old Jun 25, 2015 | 06:24 PM
Pronoun's Avatar
Both engines and ECU are non-V-TEC. I replaced the engine because the threads on a spark plug port were stripped and I lost compression. Plus the one I took out had 234,000 miles on it.
Old Jun 25, 2015 | 09:19 PM
Pronoun's Avatar
I unplugged this sensor(MAP?) on the throttle body area by the firewall, and it idles steady but a little high. At low RPM under load it sputters. As it gets going it runs well. Also, the temp gauge goes up at a a stop light. Not overheating, just warm.
Old Jun 25, 2015 | 09:27 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Did you bleed your coolant properly?
Old Jun 25, 2015 | 10:43 PM
NotARaCist's Avatar
I never narc'd on nobody!
P0133 is the only CEL code being thrown? Reset the ECU. Does the code return? Properly bleed your coolant. Put the front end on jack stands, remove your radiator cap, and start the car. Let it run for 2 to 3 radiator fan on/off cycles, keeping the radiator topped off while doing it. Doing this will also be diagnostically important for your overheating at stoplights - If your temp gauge reaches the midpoint, and your fan doesn't turn on, then we need to diagnose that as well. Start off by making sure you actually have it plugged in.
And no, a D15B is not a "direct replacement" for a D16Y7. Not even remotely.
Old Jun 26, 2015 | 03:15 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
I believe this is the best option as a 'replacement' for the infamous Y7.
http://www.hmotorsonline.com/shop/sc...age&item=30023
Old Jun 29, 2015 | 09:09 PM
Pronoun's Avatar
So, I cleaned the IACV. Fixed. I'm gonna order a new one on eBay just to be safe. I bled the cooling system too and the heat problem seems to be over. Thanks for all your help, everyone!
89rexDX
16
Aug 2, 2014 11:44 PM
blackwidow_prin
Aug 18, 2011 05:24 PM
josh_mac17
Aug 5, 2009 05:26 PM
crxSoldado
Apr 12, 2004 04:57 PM
tonesdef
Mar 23, 2003 09:06 PM
