B18c intake manifold
So i have a 96 spec b18c itr jdm i just bought a new intake manifold and im trying to take off the old one but there is a bolt in the middle at the bottom part that is in a tight spot any suggestions on getting it off without pulling the engine out ?
Use a 12mm socket with an extension, go from underneath the car and reach up high and take out that bolt! I'm assuming that it's the Intake Manifold bolted to the Head. There is also a support bracket to the Manifold that can be taken off while you are underneath too.
I've taken all of this off while working from the top too. Try harder!
Ok i work at carquest also so i just biught a flexible but holder im gonna go ahead and try of not looks like im going under thanks man
CaliforniaSi
Nov 13, 2011 06:46 AM
revolt_allmotor
Welding / Fabrication
10
Mar 23, 2005 03:19 PM
