Are these normal vacuum readings? Vacuum leak / MAF issue?
Old Jun 20, 2015 | 01:04 PM
9thgenidiot's Avatar
Default Are these normal vacuum readings? Vacuum leak / MAF issue?
I'm trying to figure out whether or not I have a vacuum leak on my '12 Civic LX.. 150k miles.. been having a super rough idle, random shaking and vibrating. Acceleration is not good, lots of hesitation picking up speed. No check engine light.
I bought a BAFX Bluetooth OBDII scanner and the Torque app to take a look at some other stuff and copied down some of the vacuum / MAF / air-fuel ratio readings to see if they help.. thinking I might have a vacuum leak since I also sometimes feel like I hear air whooshing when I'm accelerating.. but again, no CEL.
Vacuum readings:
  • When picking up speed/accelerating: 0.0 - 1.0 in/Hg
  • Cruising at highway speed (60mph), foot off pedal: 23.6 - 24.2 in/Hg
  • Idling/stopped in park: 21.3 in/Hg - 21.6 in/Hg, sometimes goes up to 22.2 in/Hg
  • Idling/stopped in drive: 19.8 in/Hg
  • When idling in park with a 22.2 in/Hg reading, I rev up to 2,000RPM and the vacuum reading goes to 23.3 in/Hg and right back down to 22.2 in/Hg when I release the pedal
  • Cruising downhill at highway speed, foot off pedal: 24.5 in/Hg
My MAF reading bounces back and forth repeatedly between 38-45g/s while accelerating uphill. When cruising with my foot on the pedal it reads 3-10g/s. When first accelerating from a stop it jumps down to 0.0 - 0.3, then shoots up to 24.0-25.0, and goes back down and hovers at 22.0-23.6.
General idle RPMs are between 700-800, usually staying right around 730-740
I checked the Mode 6 test results on my Torque app and it had a few fails mentioned.. anything that would be related?
MID: $50 TID:$0c
02 Heater Monitor Bank 4 - Sensor 4
Misfire counts for last/current driving cycles(calculated)
Min: 372.95AFR Max: 1,974.6AFR
Current: 3,276.15AFR
FAIL
MID: $08 TID:$c1
O2 Bank 2 Sensor 4
Min: 7,472 Max: 4,387
Current: 65,523
FAIL
MID: $30 TID:$0c
FAIL
The detailed chart results window mentions my air/fuel ratio as:
Air Fuel Ratio(Commanded): 14.85:1
Air Fuel Ratio(Measured): 14.68:1
Any ideas? Thanks!
steelhitman1245
Nov 23, 2011 12:30 PM
00gs-r
May 19, 2007 11:21 PM
abmerop18
Jul 16, 2006 07:10 AM
98IntegraLSNonVtec
May 23, 2006 05:29 PM
