92 civic dx hatch rear upper control arm
I need to redo all the bushings on the rear suspension for an alignment
i have the trailing arm bushings
but when i went to buy the rear upper control arm (this little tiny arm kind of in a t shape) it offered 2 options one said specifically for hatchback models
so my question is that rear upper control arm actually different on hatchback models?
i guess this part is also known as a lateral link
and off topic, but where is a good place to get the "compensator arm" that connect the front end of the trailing arm to the chassis, its like a small link.
rock auto doesnt carry them and neither does the autozone that i work at
92 DX 3D rear camber arm PN 52390-SR0-A00 right side, 52400-SR0-A00 left side
92 SI 3D rear camber arm PN 52390-SR0-A00 right side, 52400-SR0-A00 left side
92 DX 4D rear camber arm PN 52390-SR0-A00 right side, 52400-SR0-A00 left side
identical part numbers between the hatchback and sedan. From the part numbers, it appears they're the same.
95 DX Hatchback (3 door)
95 DX Coupe (2 door)
95 DX Sedan (4 door)
Id also like to know this info since I recently bought a cx 93 hatch. I believe I've got integra trailing arms since I've got rear disk brakes.
If my tailing arms are interga will all the rear suspension parts be integra parts or just the trailing arms?
You would like to know...the information that has already been posted?
Your brakes could have also come from a 92-95 SI. They have rear disc as well.
davidluko
Suspension & Brakes
Mar 30, 2009 05:47 PM
Thrashed Civic
Jul 23, 2007 05:55 PM
ev13lf
Sep 10, 2006 09:25 PM
