Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
need help
Old Jun 15, 2015 | 11:54 AM
kinoy12's Avatar
Icon2 need help
my 05 tsx 3rd gear grinds when i shift fast but if i do it slowly it dont grind and sometimes going into reverse most mechanics said its the syncho or the trans so any suggestion lmk
Old Nov 30, 2015 | 08:52 AM
TheRealMrHonda's Avatar
Default Re: need help
Typically grinding in one specific gear is a bad synchronizer, but since your're having a problem with reverse also, you may have a dragging clutch either from a master cylinder problem or a broken piece on the clutch disk. Check the master cylinder reservoir. If it is low, add fluid and check the master cylinder push rod under the dash for leaks.
Old Dec 1, 2015 | 10:13 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
^correct. Check that the clutch pedal does not have excess freeplay. It seems like most TSX clutches engage at a very low pedal position...which makes it difficult to shift fast.
I don't expect that we'll hear back, but....
Is this an aftermarket clutch? What kind?
Check clutch fluid level first. Then bleed the system. Then adjust freeplay properly. Freeplay should be between 0 and about 6mm (1/4").
mouab18c1
Oct 21, 2009 10:07 PM
88aeFC3S
Transmission & Drivetrain
Apr 13, 2009 03:21 PM
BrokeAssAcura
Mar 4, 2004 08:26 AM
95civicracer
Aug 3, 2003 04:58 PM
976
Sep 15, 2001 10:41 PM
