2000 Accord EX severe overheat
Old Jun 14, 2015 | 07:54 PM
justdon201's Avatar
Default 2000 Accord EX severe overheat
My daughter has overheated her accord on an interstate highway to the point that the car slowed and eventually stopped. Her temp gauge was not working. 3 of the 4 spark plug boots have lifted up and have become stuck or melted to the tubes. It looks like the entire radiator emptied around the cap. A thick black sludge is all around the outside of the cap. Looking into the radiator, none of the cooling tubes inside can be seen due to the amount of the black sludge stuff.
I'm sure that a new head will be needed. But, could you give me any insight as to the possibility of the entire engine being shot. Can the blocks handle such a severe overheat and still be usable? I don't know the exact letters of the engine, but I believe it begins with an "F" and ends with an "A1".
Old Jun 15, 2015 | 05:45 AM
jollyhonda's Avatar
Default Re: 2000 Accord EX severe overheat
Pick up a JDM F23a and just put a motor in the car. You can pick that motor up cheaper than the Head gasket set and head bolts and timing belt, water pump, etc. Getting that hot, the bottom end may have some life let, but it is probably getting a little asthmatic.
Old Jun 15, 2015 | 11:32 AM
justdon201's Avatar
Thanks for the reply. Any idea what one of these engines should cost?
bocajoe
Dec 8, 2015 09:40 PM
trent52hgc
Feb 19, 2015 07:35 PM
mietkiewicz
Nov 26, 2012 07:23 PM
Lester Lugnut
Aug 24, 2010 11:27 AM
clipster94
Oct 19, 2008 04:13 AM
