Transmission & Drivetrain Gearboxes, Differentials, Clutches
Can't get Type R trans back together
Old Jun 11, 2015 | 05:54 PM
Eight09's Avatar
Default Can't get Type R trans back together
So i've been trying to get my transmission back together for hours. I replaced the countershaft with a b16 complete shaft as my second gear was gone.
I've got a 1 in gap all around. Ive tried bench shifting, beating, jiggling and wiggling in every possible direction and nada. I even disassembled the trans again and still nothing.
HELP
What tips/tricks do you folks have for me?
Old Jun 11, 2015 | 06:56 PM
DVDr's Avatar
Default Re: Can't get Type R trans back together
do you have pics of the tranny without the cover to see how everything is sitting.
a buddy had same issue, turned out the case had a bearing shell, so it would have a 1" gap
Old Jun 11, 2015 | 06:58 PM
DVDr's Avatar
not a step by step, but this vid can help
Old Jun 11, 2015 | 07:02 PM
DVDr's Avatar
This bearing. the outer race can separate and stay in the case
Old Jun 11, 2015 | 08:24 PM
Eight09's Avatar
I had that issue the first time I tore apart the trans to replace that same bearing. It wanted to stick to he case. Thats not my issue as the bearing is staying on the main shaft now. I've watched that video as well. Non of the techniques worked.
Edit: Whats with the transmission in that picture? It looks either inverted or its a d series. Looks weird.
Old Jun 12, 2015 | 07:56 AM
Aquafina's Avatar
Step 1. Remove the complete B16 countershaft assembly.
Step 2. Order a new CS 2nd gear from Honda or Acura.
Step 3. Install the new 2nd gear on the original CS assembly.
Step 4. I'll answer the original question once you've done the above.
Gears develop wear patterns with each other, mixing used gears is only going to cause you more problems.
Old Jun 12, 2015 | 12:34 PM
Eight09's Avatar
Thanks.
There is about a half inch from the snap ring to the top if the bearing on the countershaft. This morning I tried what was suggested; removing one compionent at a time until it seated. I removed:
Shift change assy
Reverse shifter and gear/shaft
"C" shafts on 1-2, 3-4 and 4-5
Bearing at top of main shaft
And I gave up. Plan now it to take everything to the head tech at the local Acura dealership and have him work some magic. Otherwise there are a few manual transmission on ebay that I may have to buy since theyve been tested and are 'working'
Old Jun 12, 2015 | 06:26 PM
Dallasb84's Avatar
Dumb question but you sure your reverse shaft is in right?
Old Jun 12, 2015 | 06:29 PM
Dallasb84's Avatar
also.... Make sure the washer that has the bent tang is clocked properly. If not the case will not close. It's the washer on the main shaft I believe.
Old Jun 13, 2015 | 04:27 AM
blackeg's Avatar
this happens to me occasionally. i think the tab winds up just to the left of straight up, or like 11-1130
Old Jun 13, 2015 | 04:13 PM
ktang's Avatar
10 Year Member
Loved
Community Favorite
With me, it was from not putting enough assembly lube into the outer case for the tops of the 3 shift forks. I still had to wiggle the outer case and row the shifter until the outer case dropped.
Let us know what the head Acura mechanic says!
Old Jun 15, 2015 | 10:05 PM
holmesnmanny's Avatar
The tab for the washer that sits under the mainshaft bearing has to line up with the groove in the case or it won't fit on. This is normally the main issue.
Old Jun 21, 2015 | 06:15 PM
DVDr's Avatar
curious on what happened ?
Old Jun 21, 2015 | 06:26 PM
Eight09's Avatar
Its been a few days since I got the trans to Acura and back into the car. The trick that got the transmission was putting it in 4th and spinning the mainshaft while tapping the case halves together.
We ended up putting the original countershaft in as I had already replaced the reverse slider. My second gear synchro and spring were in better condition than B16 stuff I was going to put in.The 1-2 and 4-5 shift forks were replaced. I still have the pop out/grind issue and was told that the issue could be the linkage or shift change assembly.
For now i'm done pulling and reinstalling this thing. Next time it comes out for service its either being rebuilt properly or replaced.
Thank you everyone for your help
sirtef9
May 17, 2025 04:53 PM
jhammond_82
Feb 14, 2009 08:12 AM
be18see1
Feb 11, 2009 09:07 AM
