Transmission & Drivetrain Gearboxes, Differentials, Clutches
S80 Tapered bearing?
Old Jun 11, 2015 | 01:58 PM
carlos8's Avatar
Default S80 Tapered bearing?
Hi, I going to buy a LSD, I don't want to open the transmission yet. But I remember for the last time I open it, she have taper bearings.
This mean it's a GSR differential? LS S80 use the ball bearing type right?
Specs:
S80
66T x 15T = (4.40)
Taper bearing style
Any help will be appreciated this s80/y80 GSR or LS is driving me crazy!!!
Thanks
Old Jun 13, 2015 | 11:22 AM
94EG8's Avatar
Seagull Management
Default Re: S80 Tapered bearing?
LS/B16 trans use enclosed ball bearings, early GS-R/ITR transmissions use tapered roller bearings. Late GS-R/ITR transmissions use offset enclosed ball bearings. When replacing a differential in a transmission that had tapered roller bearings it's easiest to replaced them with the offset ball bearings as they're much easier to shim.
raverx3m
21
Dec 13, 2014 11:46 AM
Humphrizzle
Oct 21, 2013 06:58 AM
quickspool
Mar 17, 2011 08:18 AM
USDM-EK4*
15
May 5, 2009 12:36 PM
jakscivic
30
Jan 3, 2008 01:18 PM
