honda civic 95 radio no power 😠
So I have a after market radio and I was trying to find the aux connection and for some reason I lost power i checked all the wires and the fuses but I am not getting no power
can't tell which wire you are testing there should be 2 hot when the key is on.
I believe the Red is switched, on or off depending on key position
yellow is constant 12 v regardless of key on or off
Factory or aftermarket radio?
Pull the radio. Check continuity from harness like photo from above.
check for fray wires.
Make sure radio wires are correctly connected to adapters and color matched.
kimocuda
Audio / Security / Video
Nov 28, 2007 07:33 AM
Hatchback of Notre Dame
Feb 5, 2006 10:52 AM
