92 vx Gauge Cluster issues
The gauge cluster in my civic has been working intermittently for the past 3 years or so. It started as just the speedometer jumping to 110 mph then going all the way around to the bottom of resting peg and staying there all the time. About once every 100 miles or so it will start working normally until you turn the car off then it goes back to not working. Now the tachometer has started acting up also. It will fluctuate between 1400-2000 regardless of what the engine is doing. A couple months ago I pulled the cluster and cleaned all the connections then put it back in. It worked great for a little more than a week and now I am right back where I started. All the other lights and gauges still work.
Needs to be About 20% Cooler
no the "circuit card" is whats pictured in the pic above. it's a flexible plastic mounted on the back. its not a ridged fiberglass like most circuit boards are. there small boards inside for the SRS light (yellow plug) and the upshift light (white plug.)
https://honda-tech.com/honda-civic-d.../#post50284431
The post I linked above shows the circuit board of the speedo.
I had to replace it when my speedo acted just like OP's. Since I've swapped the board, the speedo and odometer/tip meter work perfectly.
Rotten_ef
Jul 25, 2018 12:35 PM
P@@RB@Y
Nov 22, 2006 03:29 PM
