15's on a 1994 Accord EX Coupe?
Old Jun 9, 2015 | 11:23 PM
thehiddencheese's Avatar
Default 15's on a 1994 Accord EX Coupe?
I was wondering if it would be too small? With eibach pro sport lowering springs, would a 2" drop be enough?
Old Jun 10, 2015 | 03:03 AM
jollyhonda's Avatar
Default Re: 15's on a 1994 Accord EX Coupe?
15s are what I plan to run on my 94 with no drop. If you aren't running a 50 series tire it should look just fine.
Old Jun 10, 2015 | 04:13 AM
Fitz Williams's Avatar
10 Year Member
The main reason for running larger rims (other than looks) is to clear larger brakes. Also, depending on your personal preference, there may be a better selection of tires and rims in the larger sizes since more cars seem to use them now.
Old Jun 10, 2015 | 12:54 PM
MAD_MIKE's Avatar
MM Gruppe B
<Pimp'n dem factory 15's yo.
Although the larger wheels will usually clear larger brakes. Reducing the sidewall height, while maintaining same diameter, will decrese sidewall flex. This will increase steering response. Reducing the marshmallow affect.
lankan-balla
Mar 24, 2012 05:43 PM
Mr. Vapor
Dec 29, 2006 06:37 AM
jordanair45
Suspension & Brakes
Jun 1, 2005 07:57 PM
mscott55
Aug 24, 2003 06:24 AM
vtec94
Aug 16, 2001 12:53 AM
