91 Accord idle issue
Old Jun 8, 2015 | 05:08 PM
91Accordkid's Avatar
Default 91 Accord idle issue
Hello I have a 91 accord lx and I am having some idle issues.
Ever since I bought the car ive had a surging idle once warm that bounces from 900-1500. Sometimes it does it other times it doesn't or it corrects itself.
Its recently been doing it after I replaced the upper intake manifold.
Ive replaced the idle control valves.
I did notice today that when I adjust the idle screw on the upper intake manifold it would stop. Is there a proper setting for this screw or an o ring that seals it? It seems that it is causing a vacuum leak or its out of adjustment.
Old Jun 8, 2015 | 07:49 PM
holmesnmanny's Avatar
Default Re: 91 Accord idle issue
You really shouldn't have messed with the idle adjust screw. Now, after you fix your underlying issue you will need to adjust that back to spec.
Start here..
Cleaning IACV, FITV and TB - Honda-Tech
Old Jun 9, 2015 | 04:35 AM
It was the issue... The screw was lose and creating a vacuum leak causing the idle surge. After adjusting the screw the surge/leak went away but it keeps coming lose.
Davesmit
Mar 24, 2019 11:27 AM
nrmskate
Sep 10, 2013 08:28 AM
Wolly1987
Jul 24, 2013 05:54 PM
mean_1
Jul 30, 2004 06:30 PM
mrpickyman
Nov 2, 2002 05:22 PM
