ecu fuse keeps blowing
Old Jun 7, 2015 | 04:06 PM
timeverlastfan's Avatar
Icon2 ecu fuse keeps blowing
hey guys I have a 1996 acura integra rs 5 speed with a stock p75 a02 ecu last night I pulled into my neighborhood and my car just quit and would not start back up lights radio everything still worked it would still crank also idk what was wrong with it this morning I checked the simple things and it turns out it was the ecu fuse in the engine compartment fuse box so I replaced it with the same amp fuse which is a 15amp and it started right up so later today I went to go pick my friend up and soon as I got to the exit it died on me again I pushed it into the parking lot and it was the same problem but this time every time I put a fuse in soon as I turn my key to accessory it blows the fuse also tried a little bit of a bigger fuse and bridging the fuse too still doesn't start I thought it would be a fuel issue because its been cutting out for a while and also so I picked up a fuel pump relay because I couldn't hear the fuel pump kick on I replaced it and same problem fuse still blows every time I know the fuel pump works because I haven't had one problem with it and I know its not the fuel relay now idk what else it could be im thinking it could be a exposed wire arching as a ground but it hasn't been checked yet idk what else to do besides that or replace my ecu and I don't have the money to buy a new one so please help me troubleshoot this problem it would be greatly appreciated thank you
Old Jun 8, 2015 | 09:23 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: ecu fuse keeps blowing
check the harness plug wires that plug into the ecu, i had a jumper harness and had a loose wire and a passenger kicked it causing the ecu fuse to blow.
Ananth
Honda Civic (2001 - 2005)
Apr 13, 2024 11:20 PM
jakscivic
Oct 26, 2023 05:17 PM
ej1 assasin
Oct 30, 2006 07:56 AM
