interior lighting/power problem
Old Jun 3, 2015 | 09:59 AM
Digitalis's Avatar
Default interior lighting/power problem
All of the sudden my interior trunk, dome, door and map lights stopped working. Also, the power doesn't stay on after I move the key to off. For example, after I shut off my car, I can't roll up the windows like I used to, I have to move the key to ON.
Cluster lights, radio and sunroof work fine
Thanks
Old Jun 3, 2015 | 10:06 AM
tcyman2718's Avatar
Default Re: interior lighting/power problem
fuse
Old Jun 3, 2015 | 10:07 AM
Digitalis's Avatar
Would it be inside an interior fuze box?
Old Jun 3, 2015 | 10:12 AM
TheMuffinMan's Avatar
He knows where you live!
You make no mention of the year or model of your car.
If it's an 94-97 Accord it's likely the 'Small Lights' fuse which I believe is in the under-hood fuse box.
Old Jun 3, 2015 | 10:13 AM
Digitalis's Avatar
Sorry it's the 97 SE. I have checked fuzes and it looks ok
Old Jun 3, 2015 | 10:38 AM
Did you actually pull them out and look at them?
Or use a tested to check that they're working?
What you're describing is very much what sounds like a fuse problem.
Old Jun 3, 2015 | 02:40 PM
Digitalis's Avatar
interior lights fuze indeed, thanks for help
mjoc13
Jun 23, 2008 07:05 PM
OneCamSlam
Acura TL, RL & ZDX
Feb 10, 2008 08:12 PM
pinoyboy204
Feb 22, 2004 06:38 PM
