New steering rack is hard to turn
Old Jun 2, 2015 | 05:29 PM
43!'s Avatar
43!
Default New steering rack is hard to turn
I got rid of my power eh steering rack for an integra, both lines were looped. The old rack I could spin with one finger when the tires were in the air. This new rack is a mother to spin, wheels off the ground. Same looped lines. Not sure why. Bad new rack?
Old Jun 4, 2015 | 02:59 AM
hondamark35's Avatar
Default Re: New steering rack is hard to turn
same part number as the old rack, you just bought a new one (remanufactured or aftermarket?) as a replacement correct?
if that is the case, try flushing some fresh fluid through a few times working the rack lock to lock. if it still doesn't loosen up it may be a manufacturing defect. could also have too much pinion preload, but unless you really want to set that yourself, it should be warrantied (I would hope)
Old Jun 4, 2015 | 10:44 AM
43!'s Avatar
43!
Yes. I think that may be it regarding the preload. Instead of removing and sending back, I purchased the tool to see if that will help.
Paul Bisioc
Jun 25, 2019 11:29 AM
VTEC junky
Suspension & Brakes
May 26, 2013 10:48 AM
732xghost
Nov 5, 2009 01:09 PM
sloweh3
11
Mar 2, 2004 04:38 AM
