F22B2 in 90-93 Accord, Which Fuel Rail?
Old Jun 2, 2015 | 04:41 PM
ZCHondaCRX91's Avatar
Default F22B2 in 90-93 Accord, Which Fuel Rail?
I put a F22B2 in my 90 accord, what fuel rail do I need that will have the fuel inlet on the passenger side so I can use the stock fuel hose?
Old Jun 2, 2015 | 04:44 PM
chrisnick's Avatar
Default Re: F22B2 in 90-93 Accord, Which Fuel Rail?
You can probably use the factory 90-93 rail.
Old Jun 2, 2015 | 06:07 PM
I tried it and there seems to be different injector spacing, it just didn't fit at all. So that makes me think it has to be F22B or F23 (unless H22 or H23 would fit).
Old Jun 2, 2015 | 06:56 PM
jollyhonda's Avatar
Is bolting your original intake up an option? The f23 rail will have the same spacing so that won't work any better. You may need to have a custom fuel line made.
Old Jun 2, 2015 | 07:04 PM
chrisnick's Avatar
Big difference in port sizes, I wouldn't recommend it. Probably easiest to get a fuel line made.
Old Jun 2, 2015 | 07:36 PM
jollyhonda's Avatar
I wonder about turning the fuel rail around so the inlet is on the passenger side. Dont know if that would work, but it may be a possibility. Either way you probably have some custom fabbing ahead.
Old Jun 2, 2015 | 10:21 PM
holmesnmanny's Avatar
No reason your stock 90-93 rail won't work.
Old Jun 3, 2015 | 06:54 AM
It doesn't work I tried it, I would have to modify how it bolts to the intake manifold and that would be a lot of work.
Actually some pretty big reasons, it simply doesn't fit at all.
Old Jul 14, 2015 | 06:32 PM
Forgot to update. I got a F22B2 fuel rail, and switch the fuel pressure regulator and fuel system pressure relief fitting around. Used the fitting to attach the fuel line and plugged the fuel feed fitting. Saw it on another thread. Works like a charm.
LivinDreamsEK9
Mid-Atlantic (Sales)
Aug 4, 2007 05:47 PM
DCFIVER
Oct 16, 2004 01:01 PM
ozzyman
Oct 1, 2003 01:02 AM
