best civic for sohc build-up?
Old Nov 4, 2002 | 03:08 PM
technotrip's Avatar
Default best civic for sohc build-up?
hey guys, Im considering starting an all-motor sohc build-up but just wondering which civic platform is the best to start with. I know gearing and weight are of big issues. And with the d16a6 i considered the swap of a1 pistons and y8 gaskets and intake mani's etc. Im curious as to what the lot of you guys would go for... im leaning towards a rex, but buddies are telling me to go for an EK with an si tranny. anyone?...
Old Nov 4, 2002 | 03:13 PM
Eee Pee's Avatar
Default Re: best civic for sohc build-up? (technotrip)
Rex is way lighter.
Old Nov 4, 2002 | 03:27 PM
mooseknuckle's Avatar
Default Re: best civic for sohc build-up? (E Prep)
Rex is way lighter.
Old Nov 6, 2002 | 04:28 AM
D16Z6racing's Avatar
Default Re: best civic for sohc build-up? (nontec)
It's not a "rex". Speak properly. CRX. It's not that hard.
And the weight isn't that much different. A stock CRX is around 1800lbs. Not sure on the EK, but the EH stock is around 2000.
EH is better looking, a bit bigger, and has tons more room. Plus more options for ANYTHING.
Old Nov 6, 2002 | 08:12 AM
owen_the_soyboy's Avatar
Default Re: best civic for sohc build-up? (buster13)
damn man, I think EK's are around 2200 for the 96-98 and 2300 for the 98+ EK hatches.
you want a CRX, if not that then a 92-93 CX/VX.
then last but not least you may be able to rock a 94-95 CX/VX
if all goes wrong, you can work with an EK, just looks much better and interior material quality is better than EG, but still heavier....
go for the sohc vtec buildup! I would not mind doing one if I had to start over!
*light flywheel, srr final drive, new cam, camgear, i/h/e, port/polish, balanced bottom end, lightened crank pulley, no accessories, 13" wheels, rear discs, full chassis brace setup, konis+gc's, sparco seat, all done!
guitarguru87
Aug 19, 2010 10:05 AM
stiruptrouble
29
Oct 11, 2007 07:08 PM
BritishBulldog
34
Aug 4, 2005 03:48 PM
hinds90
23
Jun 19, 2005 06:47 PM
