HELP Weird oil light issue 5th Gen Accord
Old Jun 1, 2015 | 07:01 AM
DFM_CD5's Avatar
Icon2 HELP Weird oil light issue 5th Gen Accord
Hi HT i have a Auto 94 accord lx i was getting a flashing oil light after driving about 20 min i had already replaced the oil pressure sender unit on the back of the block a while ago. i noticed the wire was frayed so i cut it spliced it n taped all back up the light still came on so i parked the car until i changed oil pump (water pump and oil change while i was there) and even after changing the oil pump i get a flashing oil light after about 10 min of driving and a solid oil light when stopped at a red light. Also my car sounds like it is stalling out. Actually shut off at one point. i have since parked my car to prevent further damage but im so confused i dont know what to do next. Thankz anyway
Old Jun 1, 2015 | 08:55 AM
jollyhonda's Avatar
Default Re: HELP Weird oil light issue 5th Gen Accord
What does your idle speed look like? An excessively low idle speed can cause oil pressure issues because it is not turning enough RPMs to make adequate pressure. That would also explain the stalling. How many miles does the car have on it? Does it have any knocking or other noises that could be a resultof low oil pressure?
Old Jun 1, 2015 | 09:43 AM
Digitalis's Avatar
Not to scare you, but sounds like a worm/slipped bearing(s).
Put some heavier oil into it and see if it helps.
Old Jun 1, 2015 | 03:02 PM
DFM_CD5's Avatar
OK my idle does have some issues it does the weird bounce up and down on cold start and as for when the light comes on it drops to abt 600-800 definitely below the ( 1 ) where should it be? Also it did make a weird sound when it stalled out it sounded like a grinding sound and the motor sounded like it was getting choked.
Old Jun 1, 2015 | 03:05 PM
DFM_CD5's Avatar
replace all the oil with somethin thicker or just add some what kind do u suggest? i have 5w 30 in it right now. could it be the oil is too thin for the new oil pump to keep pressure?
Old Jun 1, 2015 | 03:06 PM
DFM_CD5's Avatar
BTW Thank you guyz for the quick replies
Old Jun 1, 2015 | 03:36 PM
holmesnmanny's Avatar
It's possible you have engine damage. I would compression test to see.
Old Jun 1, 2015 | 07:13 PM
jollyhonda's Avatar
Drain all of the oil out of it and refill with something like straight hd30, something good and thick. See if you have any change in the oil light behavior. If you do, then it is safe to bet that the bottom end is loose and there may be terminal damage down there.
Wilbur21
Apr 17, 2014 04:13 PM
Gtender23
Jun 2, 2013 12:44 PM
ame28
Dec 8, 2009 05:43 PM
ZXRider
May 30, 2009 04:24 AM
mteck
Apr 4, 2002 12:32 PM
