Rear Caliper Seized?
Great forum everyone!....Had great advice my last visit and am hoping for a repeat! Had an estimate done on my 2008 Civic EX...technician said both rear brakes, and rotors need replacing and one of the calipers was seized but didn't mention which one. The passenger side brake change was easy but the left I have a couple questions on. So on the drivers side rear the life of the pad on the inside was significantly lower than the the outside pad. I also noticed the piston on the caliper was out quite a bit but I'm guessing to compensate for needing to push the pad farther to get contact with the rotor due to the minimal pad remaining...? I was able to screw the caliper piston back in but did notice one of the two plungers on the caliper bracket was seized. My main question is do I need a new caliper or just a new bracket w/ hardware or both? Would I have been able to screw the caliper piston back in if it were seized? Thanks much!
Cool Cool Island Breezes. BOY-EE
You probably just need to clean the pins with brake cleaner and a wire brush...and then grease the pins with some brake grease.
A tip: Anti sieze is not a lubricant. So don't use that.
If that fails, you may need new slider pins or a new bracket altogether. Try rockauto.com for parts.
sk8shorty012
23
Dec 27, 2010 04:52 PM
schumi
Feb 11, 2008 07:51 AM
