2002 Honda Accord SE 4 Cylinder Misfire and burning oil
Old May 31, 2015 | 07:15 PM
Jrocchio66's Avatar
Default 2002 Honda Accord SE 4 Cylinder Misfire and burning oil
I have a 2002 Honda Accord SE and am having issues. It is not loosing antifreeze but is burning oil and smoking like a locomotive. I just checked the cylinder compression on 1 - 60 2 - 200 3- 0 and 4 - 190. I checked the injectors and moved them around and cleaned and tested them they seem fine. I removed the valve cover and the valves seem to be moving well (with the fuel fuse pulled ) and rocking smoothly. The car is pushing a code of P1399 and you run then car is then gives a P300 P302 and a P303. I am at a loss of others to check. The exhaust is pulling and pushing air out. It almost sucks your hand back to the pipe and then pushes it away. The EGR and PCV are clean. The wires are connected properly. The car does not slow as you pull the # 3 wire off, but will slow when you pull the other wires. All the wires arch a spark as I pull them off. I did use Seafoam in the engine and in the gas. I also poured some Marvel mystery in the engine oil. About 5 ounces. Please help. 117000.00 miles on the car.
Old Feb 2, 2016 | 03:44 PM
Drzhope89's Avatar
Default Re: 2002 Honda Accord SE 4 Cylinder Misfire and burning oil
burnt exaust valve buddy no cylinder number 3
Old Feb 3, 2016 | 05:57 AM
Jrocchio66's Avatar
Yes it was burnt exhaust valves. Put on a new head and rings. The car is running back to specs
Jrocchio66
Aug 12, 2015 07:15 AM
soLame
Jan 22, 2014 10:40 AM
bwta
Jan 25, 2012 10:31 AM
hondaaccordf23
Dec 14, 2011 06:01 PM
theskabeater
Oct 13, 2008 03:54 AM
