Thermostat housing
Old May 31, 2015 | 09:37 AM
ednroc's Avatar
Default Thermostat housing
I have an '89 Prelude 2.0 si coup auto. the thermostat housing is cracked and it's very hard to find a replacement. Can a '88-'91 Prelude 2.0 SI thermo housing fit?
Old May 31, 2015 | 12:27 PM
thirsk66's Avatar
Default Re: Thermostat housing
Yes you can use one from the 88-91 Prelude SI's they are all the same and share the same part numbers.
Old Jun 3, 2015 | 11:47 AM
ednroc's Avatar
Can someone tell me where I can get a new or used thermo housing 1989 prelude 2.0si. Also can the cracked one be welded?
Old Jun 3, 2015 | 01:36 PM
thirsk66's Avatar
Honda does not make new ones anymore as they have been discontinued. Oreillys sells the thermo housing cap not the complete housing setup. I would look in junk yard or parts dismantlers in your area for a used one and see what you can find. Also I wouldnt recommend welding that cracked unit as its not high quality metal and will most likely do more damage then good.
Old Jun 3, 2015 | 02:52 PM
ednroc's Avatar
Thank you. o'reilly has it.
JDMCRX
May 18, 2005 07:18 AM
SiPrelude
Feb 27, 2003 08:23 PM
