Place Racing Crossmember...
Old Nov 4, 2002 | 02:41 PM
Eggman's Avatar
Default Place Racing Crossmember...
are the only benefits header/turbo clearance? any handling/wheel-hop benefit like the z10 and jimfab?
Old Nov 4, 2002 | 02:51 PM
tunedcivic's Avatar
Default Re: Place Racing Crossmember... (Eggman)
and where to find and how much?
Old Nov 4, 2002 | 05:53 PM
Wes V's Avatar
Default Re: Place Racing Crossmember... (tunedcivic)
1) It's lighter.
2) With it, you can use their fourth motor mount (although I'd bet that it is only if you use the other three Place Mounts and not Hasport mounts)
3) You can use the radiator from the 92+ Civics and it's supposed to be better. What I don't understand is that it appears to be smaller in dimensions, but is dual core. The radiator in my 89 Si is full width and I'm wondering if it's possible to get a dual core version made up.
Wes.
Old Nov 5, 2002 | 12:50 PM
B16CRXSi's Avatar
Default Re: Place Racing Crossmember... (Wes V)
I just bought one the other day. It is suppost to be lighter and give you more room to fit a bigger header than stock. It also come with a front motor mount. Four mounts are always better than three. My other mounts are also place racing so I don't know if it will work if you use motor mounts other that place racing. I got mine from JDMhondaparts.com. I payed $150 pluse shipping thats the crossmember and mount...
Old Nov 5, 2002 | 12:56 PM
Jared's Avatar
the problem with the place racing is that it still uses the stock bushings for the radius rods. not worth it imo, thats most of the point of getting one. i recommend the jimfab.
Old Nov 5, 2002 | 01:00 PM
JdM-BRiD's Avatar
Default Re: Place Racing Crossmember... (B16CRXSi)
I'm using a Koyo Radiator off of a 90-91 Integra, and it fits perfect in the crx, except it's a lot thicker. I hink i might need that crossmember, cuz i'm runnin 4-1 headers from dc sports for a type r and i had to remove the a/c fan for it to fit. How much is it?
93slmdcvcsi
Feb 1, 2004 11:09 AM
WhiteLightening
16
Jan 4, 2004 08:29 AM
E-lude78
13
Oct 9, 2002 07:05 PM
EF_LSVtec
56
Sep 13, 2002 07:42 PM
bigTom
Jan 27, 2002 05:01 PM
