I pulled the motor apart and noticed that the bearings were not in the best of conditions. so before I put the motor together I decided to send it off to the machine shop. Got the head done up and resurfaced. Got the crank polished.
Today I was still waiting on the block to come back and still have not received my bearings yet. So I decided to strip down and clean the transmission to match my block
Thanks. Its my first build all on my own so im taking my time
Just got all new oem bearings and rings. Got my front and rear main seal. all new gaskets for the whole motor. New water pump, tensioner, spring, belt. Only have half the money so im picking up my block and crank tomorrow so I can start to assemble my bottom end till I get the money for the head.
So I got my block and crank back from the machine shop today. Decided I would clean and scrub the block down and give it a good paint job. Started putting things on the motor such as my new water pump. Tensioner. Spring. Any parts I could get back on in the time I had today I did.
The cylinders have been honed, block was resurfaced, crank was polished.
I am still waiting on my damn bearings and rings to come in the mail!!
Tomorrow I am going to put in new front and rear main seals!
Still creeping along in between work! just picked up a set of rust free eg hatch doors for 25 bucks! a steal! almost have the car ready for paint and have the main bearing clearances all checked and in spec as I figured with the oem replacements. All of my rings are perfect Waiting on Oem rod bearings to put the pistons in and all I am going to need is a head gasket. Hoping to have it fired up by next week!
Did a little body work messing around today and thennnnnnnnnnnnn I finally got my rod bearings in the mail. I will posting some pics of the bottom end tomorrow
Been a bit since I posted been swamped with lots of work today and prepping for the winter . Spent some time today getting everything back together and torqued to
Spec. Just picked up 2 new snap on torque wrenches and let me tell you I love them!!
But all the talking aside I got the motor ready to put back in.
Got around to putting the motor back in today after doing a check over the ptv clearances . Picking up everything I need to finish toMorrow and going to fire it up . Can't wait
Everything went smoothly
What did you use to.clean it? Very effective i must say
Been a while since I posted but just painted the car the other day. Still needs a little lining up and love . Finally got a windshield coming next week and registered . I'll post it up.
Thanks guys. And yea it's been a pain in the *** to find parts . I had way more luck picking up parts cars on a local Honda page. Worked out cheaper than individually picking up parts. After all I've done I'm still only 2 grand into the car!
