1997 Accord Air Conditioning Thermostat
Old May 27, 2015 | 04:10 PM
BloodOfTheNorth's Avatar
Default 1997 Accord Air Conditioning Thermostat
I've been lurking on this forum for days now but can't seem to find what I'm looking for so I decided to register and ask directly. With the help of this forum I've discovered that I have a faulty A/C thermostat. What I can't seem to figure out is how to remove said thermostat from the evaporator. I'm really hoping step one isn't "Remove the evaporator". Thanks in advance guys and I hope to hear from somebody.....(anybody?)....soon.
Old May 27, 2015 | 04:17 PM
rockycat's Avatar
Default Re: 1997 Accord Air Conditioning Thermostat
Can not get to it with the evap installed.
Old May 27, 2015 | 04:37 PM
I can get to the part that plugs into the pigtail, just not the part that goes into the evaporator. Whats at the other end? A bi-metal switch? What part of the thermostat usually goes bad?
Old May 27, 2015 | 05:00 PM
rockycat's Avatar
It is called a thermister. Replaced a few and never a controller.
Old May 27, 2015 | 05:03 PM
holmesnmanny's Avatar
It's highly unlikely your thermostat is bad. Either a leak in the system or the expansion valve being bad are normally the two most likely culprits.
And the thermostat sticks inside the evaporator and wraps around the inside of it. You can't get it out without taking out the evaporator.
Old May 27, 2015 | 05:18 PM
rockycat's Avatar
picture of a general location.
Old May 27, 2015 | 06:21 PM
Holmes, it's definitely the thermostat. Jumped the pigtail and engine idles up, condensor and radiator fans run and compressor engages. Rocky, that's not the evaporator on a 97 Accord and Honda refers to the part as "Thermostat, Air Conditioning".
Old May 27, 2015 | 06:25 PM
rockycat's Avatar
As I poster "GENERAL" to give you a idea of things.
Old May 27, 2015 | 06:47 PM
v4lu3s's Avatar
RTFM
Regardless of the diagram being perfect or not I see no way to remove and then reinstall a thermostat with an installed evaporator.
Old May 28, 2015 | 10:05 AM
Its part 19 top right
jackhis
Jun 18, 2022 10:26 PM
TeknoGodz
Apr 19, 2015 11:30 PM
dcurcic
Nov 23, 2011 06:06 AM
Buzzbomb
Jan 20, 2009 06:02 PM
stevescivic
Jul 30, 2004 04:10 PM
