Lighting HID/Xenon kits, Retrofits and Associated Topics
To un-HID my car
Old May 27, 2015 | 03:01 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Default To un-HID my car
My car came with aftermarket HIDs. One of the past owners installed them. One side is bad, so I want to go back halogens.
Questions:
B is where the headlight goes. Unplug from the ballast, and plug into the halogen bulb.
What is A? What do I do with this if I want to disable it HIDs?
Old May 27, 2015 | 10:56 PM
underrated's Avatar
Default Re: To un-HID my car
B does not plug into your headlight. The plug will match the backside of the halogen bulb.
Does this "kit" have a separate wiring harness? Locate the headlight plug closest to the battery and check.
Old May 28, 2015 | 11:26 AM
LowTEC SaiMike's Avatar
Unplug everything that is attached to the car . you should be removing 2 pieces . Then the car side plug should plug directly into the halogen light
Old Dec 11, 2015 | 07:37 AM
boost21's Avatar
like the post above, remove the ballast (big box) and hid bulb, then take plug b and connect it to a halogen bulb and put that back in the headlight.
kaivorth
Honda Civic (2001 - 2005)
Aug 18, 2017 02:47 AM
EvenStar
Jan 25, 2007 05:30 PM
crazzyviet
Jul 24, 2005 01:11 AM
slowacura
Nov 22, 2003 10:11 AM
