00 Civic Dx coupe/D16Y7 - oil pressure warning light
Old May 25, 2015 | 04:27 PM
Junior_rigo's Avatar
Default 00 Civic Dx coupe/D16Y7 - oil pressure warning light
Okay here is the story i finally got my car to run. After like month in a half. Got a new engine on it (well not new used junk yard engine on it) but runs good. Only one problem every time i start it, mostly when i cold start it, the check oil light shows up & stays on for while & turns off. its doesnt make a nosie of some sort just a normal start. But after i start to drive it for a while the light keep on turning on & off. Blinks very fadely, & turns off. After it turns off, awhile later my car turns off while i am braking or have it in neutral. Then it starts right back up like nothing happens. any idea on what it could be? i change the oil pressure switch like three time & it does the same thing? Help?
Old May 25, 2015 | 05:04 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Ek civic coupe Help!
Instead of just continually replacing the sensor, you need to actually test your oil pressure. That light is a dummy light. If it's on, you have next to no oil pressure. You've probably already damaged the bearings.
Old May 25, 2015 | 05:12 PM
Former User's Avatar
Post car and engine information.
Old May 25, 2015 | 05:33 PM
2000 Honda Civic Dx, D16Y7 SOHC. 1.6L
Old May 25, 2015 | 05:34 PM
Damn alright gonna check the oil pressure Thanks for the information.
ShadowDaisy82
Honda Civic (2001 - 2005)
Mar 15, 2018 09:57 PM
Daniel Mata
Apr 7, 2014 09:18 PM
Newbie3000gt
Mar 19, 2013 08:00 AM
Funkin Flux
Mar 17, 2006 10:12 PM
PatrickGSR94
Dec 19, 2004 07:45 PM
