Cluster swap questions
Old May 24, 2015 | 07:47 AM
Grandhustleman86's Avatar
Default Cluster swap questions
Im in dire need of a Wiring Diagram/pinout for a A/T 94' or 95' 4cyl 4door Accord Cluster. Doing a cluster swap into my 95 odyssey. Hoping im not gonna have to go to crazy doing it since they were both obd1. Thanks for any info
Old May 24, 2015 | 08:00 AM
Lost Again's Avatar
Default Re: Cluster swap questions
Do you need "pins" or "which pin" for X?
Old May 24, 2015 | 08:16 AM
coolswimmerjon's Avatar
I'm not sure if this will help.
Old May 24, 2015 | 08:29 AM
Lost Again's Avatar
here are the "pins"
Old May 25, 2015 | 01:01 AM
Whats up lost. Yeah man your on point but im looking for the pin number-color combination-function of each individual wire almost like what Coolswimmerjon has but alot simpler like ex. (A1 - blk/grn - door ajar indicator). Or at least the corresponding images/documents so i can break it down for simplicity while im in the dash labeling.
Old May 25, 2015 | 03:28 AM
Lost Again's Avatar
Never broke it down that far.....also the Accord wire color might not match the Ody wire colors
Old May 25, 2015 | 07:12 AM
Lost Again's Avatar
USE AT YOUR OWN RISK !!!!!! NOT RESPONSABLE FOR ANY DAMAGE DONE or ERRORS
A Connector
A1 – BLU/RED – Power to brake check
A2 - ORN/WHT – high beam light relay
A3 – RED/YEL – Power High beam, under hood fuse 19
A4 – LT GRN/RED - ECM
A5 – YEL – Power dash fuse 1
A6 – BLANK
A7 – GRN/BLU – Left turn signal light
A8 – GRN/RED – Brake switch/Level switch
A9 – BLK – Ground (g402/g404)
A10 – RED/BLU – Driver’s seat belt
A11 – GRN/YEL – Right turn signal
A12 – BLU – From SRS unit
B Connector
B1 – BLK/WHT – dome light – door position
B2 – GRN/WHT – Right rear door switch
B3 – GRN/RED – Pass door switch
B4 – ORN – Trunk light
B5- GRN/ORN – Drivers door switch
B6 – YEL – Power dash fuse 1
B7 – RED – Dash brightness controller
B8 – RED/BLK – Combination light switch
B9 – YEL/GRN – Temp sending unit
B10 – BLK – Ground (g402/g404)
B11 – BLANK
B12 – BLU – ICM tack input
B13 – WHT/GRN – Tail light failure sensor
B14 – GRN/YEL – Left rear door switch
B15 – BLANK
B16 – BLANK
B17 – BLANK
B18 – WHT/GRN – Hazard power, under hood fuse 35
B19 – YEL/RED – Oil pressure switch
B20 – WHT/BLU – Alternator light
B21 – WHT/RED – Hazard light switch
B22 – BLK/YEL – Charging light power, dash fuse 4
C Connector
C1 – YEL/BLU – Fuel gauge input from pump
C2 – LT GRN/RED – Low fuel light input from pump
C3 – BLU/RED – TCM ??? D4 light?
C4 – BLANK
C5 – GRN/WHT – Park light
C6 – GRN/RED – Reverse light
C7 – GRN – Neutral light
C8 – BLANK
C9 – Ain’t got a F’n clue what the hell this one is?
C10 – BLANK
C11 – BLU/BLK – Cruise control light, CC unit
C12 – ORN – VSS input to odometer and speedo
C13 – LT GRN/WHT – D1 light
C14 – GRN/YEL – D2 light
C15 – LT GRN – TCM when park or neutral - - starter circuit
C16 - GRN/BLU – D3 light
Old May 26, 2015 | 07:15 PM
Thats what im talking about man. I started looking at service manuals today. Ive already got my ody's harness ready, now its just matching up, solder and heat shrink my all the accord plugs to the ody's harness. Thanks alot man for helping out. Been a 4-5 day process here figuring the ody's harness but its all labeled and ready to go. Ill confirm the list you put up here to the service manual before i jump in. Ill shoot some pics when i get it all done and installed. Lost thanks again man.
Old May 27, 2015 | 03:25 PM
Lost Again's Avatar
I got bored on the holiday , nothing better to do.
Again, I have the "paper" version of the 95 service manual and the cheap/suspect on-line version of the 94. I used the two to come up with what I posted. AT YOUR OWN RISK!
And if anyone can tell me what the heck C9 is.....thank you....and I'll edt the post to reflect.
Old Jun 9, 2015 | 03:05 AM
Hey Lost i figured out what the C9 blue/white is for. Lol After a little more indepth research its the ABS fault indicator light for the 95 accord cluster. Hope that helps. Thanks again man.
93typeS
Mar 15, 2015 02:48 PM
DRAGON JOEY
Jul 29, 2010 07:45 PM
jdmCD695
Jun 14, 2008 11:51 AM
Accorn
Jan 6, 2006 11:44 AM
