what's the trick to remove the factory power antenna on a 1991 integra..
Old May 23, 2015 | 06:50 PM
Cm91h22a's Avatar
Default what's the trick to remove the factory power antenna on a 1991 integra..
Factory power antenna on 1991 acura integra has been broken for a while. Trying to remove it but can't get it out. Any advice would bE appreciate appreciated, did a search with no luck.
Old May 23, 2015 | 08:33 PM
91akira's Avatar
Default Re: what's the trick to remove the factory power antenna on a 1991 integra..
Thats funny. I just went to the junkyard to pull one out. If your talking about the antenna shaft only and not the whole assembly thats is the trunk then, You'll have to remove the nut on the surface of the car. Use some strong needle nose pliers to unscrew the nut off. Once that is off, pull as hard as you can the antenna. This will probably be really hard to get off. spray some wd 40 on it and kinda use a back and forth twisting motion upward. Keep going all the way up until the antenna is out. Good luck
matt203
May 11, 2013 08:22 PM
sobey
Mar 4, 2009 07:06 PM
GSTegTravis
Nov 13, 2007 01:36 PM
TAG
Jan 27, 2002 03:53 PM
