'97 Honda Accord V6 2.7L Ground locations
Old May 22, 2015 | 11:40 PM
fleabag's Avatar
Default '97 Honda Accord V6 2.7L Ground locations
Anybody have a good list of where the electrical grounds are on this car? I've already cleaned up quite a few in the engine bay but I know there are more grounds that should be cleaned. One reason why I know is because the oxygen sensors are very slow to go from open loop into closed loop mode and are eager to switch back into open loop mode. Typically I have found vehicles like this have this issue due to weak electrical grounds. This car definitely has a grounding issue as every ground I've cleaned up on the car was pretty corroded. Despite a new alternator, the car was only charging at 13.6v and it would drop down to battery voltage of 12.5v if AC/FAN HI, HIGHBEAMS were on.
Now, after cleaning the alternator positive terminal and all the engine bay grounds that I can think of, charging voltage is a better @ 14.1v and it sinks down to about 13.2-13.0v if I turn on the AC/FAN HI, and Highbeams. I can't even test the electrical system with the rear defrost because the rear defrost button and potentially system does not work.
Old May 23, 2015 | 03:20 PM
holmesnmanny's Avatar
Default Re: '97 Honda Accord V6 2.7L Ground locations
parts store alternator remans are going to be a crapshoot .. its best to get a denso alternator
odds are the issue lies with the one you bought rather than a ground issue and alternators produce max output at 1500+ rpms
chellz
May 30, 2015 08:26 PM
devildawg3267
Jun 30, 2013 11:47 AM
radoak
Jul 24, 2012 09:15 PM
smrogers
Aug 24, 2009 11:53 AM
oldchicagoguy
Oct 21, 2004 03:47 PM
