Integra running sluggish
Old May 22, 2015 | 07:41 PM
potatointegra01's Avatar
Default Integra running sluggish
B18b1:
I had a valve job done and now that everything back together the car doesn't idle I have to push on the gas to keep it idling. If I remove the hose going to the intake it will idle high so I deciding to see if it will run and it ran very sluggish.
Any help for why it won't idle?(all the sensors are in the right spot)
And why does it run very crappy and sluggish?
Old May 22, 2015 | 08:50 PM
White_EG1's Avatar
Default Re: Integra running sluggish
So when you remove the hose from the intake to valve cover the idle rises? If so this could be a vacuum leak. For sluggish performance, did you do the valve job yourself or take it to a shop? Check you're mechanical timing also.
Old May 23, 2015 | 09:44 AM
wunfstgsr's Avatar
Loved
Community Favorite
Why do you make multiple threads for the same issue?????
https://honda-tech.com/acura-integra...-help-3248498/
https://honda-tech.com/acura-integra...se-do-3248352/
https://honda-tech.com/acura-integra...-crap-3248351/
https://honda-tech.com/acura-integra...-help-3248259/
https://honda-tech.com/acura-integra...-help-3247610/
You could have a coolant temp sensor issue on cold starts causing you to need to hold the throttle to keep its idle.
Or it could be a IACV issue where its not plugged in or its dirty and needs to be cleaned or replaced.
Have you checked your mech. and ignition timing?
potatointegra01
May 22, 2015 07:40 PM
mayfly
13
Jun 2, 2010 01:25 AM
Ahknodd
Oct 21, 2006 09:31 PM
caliquick_teg
Jan 23, 2003 05:34 AM
