5 Lug Conversion
Old May 22, 2015 | 11:35 AM
sg_81's Avatar
Default 5 Lug Conversion
Looking into doing the 5 lug conversion on my 98 accord sedan but i want to hear some input. Pro's/Con's and who has done it in the Los Angeles area that can coach me through it if i do go through with it.
Old May 22, 2015 | 09:27 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 5 Lug Conversion
There was a writeup on a 5 lug conversion in the FAQ at the top of the page for 6th gen.
Fairly simple on '98-02's as the V6 cars were 5lug, just swap the complete uprights/spindles/knuckles from a V6 on you your I4 car.
Old May 23, 2015 | 07:05 AM
sg_81's Avatar
So how come some of the post make it more complicated if its that simple. What would you estimate the cost to be on something like that?
Old May 23, 2015 | 07:09 AM
sg_81's Avatar
I cant seem to find that thread your talking about MAD_Mike
Old May 23, 2015 | 09:17 AM
jollyhonda's Avatar
On the 94-97 Accord it is more complicated than that.
Old May 24, 2015 | 02:18 PM
MAD_MIKE's Avatar
MM Gruppe B
On 90-97 cars it is a bit more complicated yes. These are the more common threads that are on the net.
98-02 cars were 4 lug for I4 and 5 lug for V6.
What part is complicated?
Pretty sure both cars used the same taper on the ball joints and suspension links, as well as stub axle splines.
If your car is originally rear drums then the rear hard lines and hoses will need to be changed and the MC may need to be changed if it is a different piston diameter to maintain correct pedal feel. Also rear parking brake cables from drum to disc.
If your car already has disc rear, then I would suspect the hard/soft lines are the same.
5-lug and Rear Disc Swap
Although the title on this thread should read '98-02 5-lug and Rear Disc Swap'.
Post #21 has rehosted pictures.
Old May 26, 2015 | 07:26 AM
sg_81's Avatar
Mine came with disc brakes in the rear. So your saying its as easy as just swapping the parts from a v6 from the same yr and it should be fine?
Old May 26, 2015 | 09:09 AM
TheMuffinMan's Avatar
He knows where you live!
Doesn't even have to be the same year. 98-02 V6 Accords were all 5-lug.
The 4th and 5th generation Accords were significantly more work.
Old May 27, 2015 | 12:59 PM
MAD_MIKE's Avatar
MM Gruppe B
Yeooooop.
Check out the post in the link I provided above.
Old May 28, 2015 | 11:19 AM
sg_81's Avatar
Thanks guys for your help.
DC2_2
Jul 24, 2006 09:54 PM
guywitaDA
Jul 13, 2005 06:29 PM
LCDeuce
May 20, 2003 04:13 PM
mikeyvt
Mar 2, 2003 11:05 AM
LillDragun
Nov 21, 2002 04:36 PM
