What do you think of these gears?
There's no indication of teeth missing due to damage, so you're likely good.
What's the model of this transmission; or what's the year, model, & trim of vehicle that this transmission came out of?
My guess is that it is a GSR trans due to spinning the input shaft and getting the roughly 4.5 spins out of the axel holes.
look at the wear in the grooves on the hub from the first picture I think its the 3-4 selector on the mainshaft. it may grind slightly. u can probably take it off and clean it up with some sandpaper or a fine tooth file. check the ring as well make sure its not worn or bent to avoid pop outs
1993gsrcivic
Transmission & Drivetrain
Jan 20, 2009 09:16 AM
