99 accord starting problem
Old May 20, 2015 | 05:32 PM
reddcoupe's Avatar
Default 99 accord starting problem
hello everyone i did a compression test on the car today on 3 cylinder I got 125 and 75 on one would that stop the car from starting
Old May 20, 2015 | 07:13 PM
holmesnmanny's Avatar
Default Re: 99 accord starting problem
I would say it's possible. Have you checked your mechanical timing yet ? You may have jumped a tooth.
Old May 20, 2015 | 08:32 PM
reddcoupe's Avatar
Yes timing was check and it's fine the key was checked ignition switch distributor replaced I even dropped the fuel tank drain it put it back took the exhaust off the car just refuse to start I have never seen this before I am at the point now I am planning on switching the motor
JYarber18
Mar 4, 2019 05:25 AM
kylelovesbass
Jul 24, 2014 12:22 PM
Mikevar82
Apr 13, 2014 04:47 AM
