Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
BMXA trans rebuild
Old May 19, 2015 | 03:58 PM
Topher75's Avatar
Default BMXA trans rebuild
How much interest is there in a BMXA rebuild guide? I am in the process of getting ready to rebuild mine.... can take pictures and put it together if there is enough interest. By the way, new member but a long time lurker.
Old May 20, 2015 | 12:54 PM
It Wasn't Me's Avatar
Default Re: BMXA trans rebuild
Originally Posted by Topher75
.. a long time lurker.
As many people are.
I wouldn't consider a lack of replies as a lack of interest. If you're up for it, I'm certain a lot of people will appreciate the DIY!!
Old Jun 2, 2015 | 05:37 PM
dogwheely's Avatar
im interested and expect to have to rebuild my BMXA due to some bad bearings that are growling
Old Jun 2, 2015 | 05:43 PM
dogwheely's Avatar
yes I'm interested due to some bad bearings in my bmxa transmission sorry if this is redundant
Old Apr 1, 2016 | 08:36 PM
malibu_rod's Avatar
Did this ever get done? I'm really interested.
Old Apr 22, 2016 | 09:42 AM
dogwheely's Avatar
Not yet waiting for my brother's shop to clear out will probably get to it this summer sometime
Old Apr 22, 2016 | 09:44 AM
dogwheely's Avatar
Good luck wth yours!
Old May 3, 2016 | 09:55 AM
malibu_rod's Avatar
I'm going to pull the motor and transmission this weekend. Motor needs to be replaced, bought the car for cheap. So figured I get into the transmission and rebuild it as the car has 200K. Will swap the motor with a JDM I can get those for around 550.00~600.00 not worth rebuild the motor for the cost of the swap. I did read up on the process and I have the official Honda Manual watched a couple videos of the tear down one is really detailed. A little bummed the guy didn't do a rebuild video of the BMXA. He has some rebuild videos of other Honda transmissions. It looks pretty straight forward and no real special tools except of the P/N: 07GABPF50101 main shaft holder not sure exactly how that comes in to play ( Looks to hold the main shaft upright on dissemble and reassemble as far as I can tell from the manual.
Old Dec 4, 2024 | 07:32 AM
kabrilake's Avatar
Instead of the $70 mainshaft holder, I used a 22mm box end wrench, then packed the groves with finish nails. I used 2 different sizes of finish nails, some I had to gently tap in with a nail set and hammer. Once the wrench was firmly attached (no wobble) and turned the shaft, I then put a small bolt in one of the bellhousing holes to keep the wrench from turning. For me (SDMA trans) the mainshaft nut was a left handed thread, so I turned clockwise to loosen it. Worked great and was pretty quick.
silverwrench
Transmission & Drivetrain
Aug 6, 2009 09:28 PM
JMinSi2000
Dec 12, 2003 02:18 PM
InfamousRS
Feb 13, 2002 07:42 PM
