2001 integra radiator fans not coming on
Ive noticed that the radiator fan has not come on when driving or at operating temperature.. could it be relay? Switch thermostat? Also the ac does not work either. Any help would be appreciated.
1. Is you vehicle overheating?
2. Have you let you vehicle idle for several minutes probably 15-20 to see if fan comes on
3. Have you attempted to hot wire it( just to check and see if it works not permanently!!!!!)
Your A/C is a hole other gremlin, that we can work on after these questions have been answered
From what my temperature gauge tells me it's not overheating..yes i have let it idle for 20 minutes even when im driving for 30-45 mins still no fan...my next thing was to hot wire the fan motor to see if it kicks on.. ac i will worry about after i get this issue solved
2Cleezy
Sep 2, 2005 08:48 AM
