Certain gauges won't work after replacing a bulb in instrument cluster
Old May 18, 2015 | 01:25 PM
Nicholls's Avatar
Default Certain gauges won't work after replacing a bulb in instrument cluster
I recently just took apart the dash in order to replace a bulb in my instrument cluster. After putting everything back toghether, I noticed that the fuel gauge just goes all the way to the top even though I have a half tank of gas.
I then took everything back apart and checked it out and made sure everything was connected, only problem is, when I put it back together, now the temperature gauge does the SAME thing.
Any suggestions?
Thanks!
Old May 23, 2015 | 12:14 AM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Default Re: Certain gauges won't work after replacing a bulb in instrument cluster
Any suggestions?
Thanks!
if you look at the temp and gas when disassembled there is a roll of copper wire and a single strand of copper wire that receives voltage. This in turn gives you your gas gauge and coolant readings. I am certain when you were tightened those little screws behind the circuit, you definitely put too much pressure which cause the single fine strand of copper wire to snap. Hence why you are not getting an electrical signal. Go to the junk yard and find a a similar car as yours and take what you need. Be certain to GENTLY and LIGHTLY tighten those screws.
Old May 23, 2015 | 06:26 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
What year and model trim is your car?
zxpher1
Aug 25, 2009 06:30 PM
tekniq
Jan 14, 2009 08:38 PM
speddiek
Oct 10, 2008 01:01 PM
bigboi_626
Jun 6, 2007 10:27 PM
sf@rx7
Feb 17, 2006 07:42 PM
