f22b2 safe nitrous
Old May 18, 2015 | 10:21 AM
projectDB7's Avatar
Default f22b2 safe nitrous
just bought a zex wet nitrous kit and was wondering exactly how a window switch would work out? Can I still use the WOT switch that comes with the kit? And would the nitrous still only be fed at the set rpm range or would the WOT switch over ride that? And would I need a different fuel pump? (It's only going to be a 75 shot so I'm assuming oem fuel pump should be able to deliver enough fuel)
Old May 18, 2015 | 05:18 PM
jollyhonda's Avatar
Default Re: f22b2 safe nitrous
I am by no means an expert on nitrous but I know electricity. And if you have an rpm switch and a WOT switch, and wire them in series, your solenoid would only operate when both switches are closed. I am not sure exactly how you want the nitrous to work, but it sounds like you want it only at WOT above certain RPMs. Is that correct?
Old May 18, 2015 | 05:35 PM
projectDB7's Avatar
Exactly what I want, so I'd have to wire as series not parallel? Is it possible I'd run into a problem with not providing enough power to one of the switches? (sorry I'm completely new to wiring)
EDIT: then again wiring them as parallel circuit's would cause both switches to operate individually meaning Id be feeding nitrous anytime I go WOT as well correct?
Old May 18, 2015 | 06:51 PM
jollyhonda's Avatar
You are correct. In parallel you would hit the solenoid anytime either parameter is met. Series it will only be when both are in.
Old May 18, 2015 | 10:29 PM
Tachi's Avatar
I thought that the WOT switch was more of a safety than primary activation.
Old May 18, 2015 | 11:05 PM
projectDB7's Avatar
From my understanding both the window and WOT switch are safety switches in the sense that the nitrous is only injected under certain circumstances but since it does indeed dictate when nitrous should be injected I'd consider it an activation switch as well, but of course I could be completely wrong
BIG T
Feb 26, 2008 12:45 PM
BIG T
Feb 23, 2008 03:16 PM
lsvtec225
Mar 18, 2007 05:28 AM
TurboT
Nov 9, 2003 04:50 PM
kefka
Feb 27, 2002 07:47 PM
